denso alternator
Posted: Sun Dec 07, 2014 11:59 pm
by jdavis
Has anyone switched to the denso alternator for running extra lights and a cooling fan??
Re: denso alternator
Posted: Mon Dec 08, 2014 7:54 am
by dubs
I run one on my 72 charger, will probably make the swap on the truck eventually. Just make sure to bypass the ammeter in the dash and run an extra heavy gauge charging wire direct from the battery to the alt stud, especially if you have stock wiring. Those alts can push a lot of amps.
Posted: Sun Dec 14, 2014 12:19 am
by jdavis
I'm getting all my parts together to make the switch to the denso alternator on my 66 powerwagon and on my 65 Barracuda Formula "S". Thanks for the info on the wiring and bypass issue.
Posted: Sun Dec 21, 2014 11:13 pm
by sweatybetty
dubs wrote:I run one on my 72 charger, will probably make the swap on the truck eventually. Just make sure to bypass the ammeter in the dash and run an extra heavy gauge charging wire direct from the battery to the alt stud, especially if you have stock wiring. Those alts can push a lot of amps.
is that internal or external regulated?
Posted: Mon Dec 22, 2014 9:26 am
by dubs
It's externally regulated, with dual field terminals. I run the same solid state voltage regulator that is standard on ~71(?) up mopars, standard# VR125.
Edit: The denso alternator part number is 210-0138, and you can find it in the interchange as an option for an '88 D150 with a small block. Several different companies make aftermarket bracketry to fit it to big blocks, or you can cobble your own from junkyard pieces.
