Single speed wiper switch breaker trips
- my5thmopar
- City: Columbia
The breaker in the switch trips but, then resets, Motor runs 5-6 seconds, breaker resets 10-11 seconds and repeats. Bad switch or motor OR ground? Thanks
1964 D100 Utiline
2019 Ram Classic
viewtopic.php?f=34&t=40251
2019 Ram Classic
Re: Single speed wiper switch breaker trips
I am thinking motor dragging from lack of lube causing high amp draw.
- my5thmopar
- City: Columbia
Ya I was wondering about that from sitting in a field since 88. I got PM about the motor. I'll try to clean it up first and see if I can get it working. Thanksdodgeboykim wrote:I am thinking motor dragging from lack of lube causing high amp draw.
1964 D100 Utiline
2019 Ram Classic
2019 Ram Classic
Mine did the same thing, and was the switch shorting out internally.
- my5thmopar
- City: Columbia
Re: Single speed wiper switch breaker trips (Fixed)
Bingo...Gold star for you. Took motor a part, cleaned terminals and such, new lube works great now.dodgeboykim wrote:I am thinking motor dragging from lack of lube causing high amp draw.
1964 D100 Utiline
2019 Ram Classic
2019 Ram Classic
my5thmopar wrote:Bingo...Gold star for you. Took motor a part, cleaned terminals and such, new lube works great now.dodgeboykim wrote:I am thinking motor dragging from lack of lube causing high amp draw.
I accept bills in small denominations but none from other countries. Only U S or Canadian money.
Glad you found the problem.
