I am getting close to having the '69 back on the road, but to pass inspection here in Texas, the windshield wipers have to be functional. I tried them out this weekend, and when I turned on the switch, the arms moved about 1/4" and froze. I left the switch on, and was going to move them by hand and try and "gently force" them, but before I could get to them to move them, the motor (or wiring) under the dash started smoking. So I turned it off, sprayed them down with WD-40, and just left them over night. I hope to go back out and take a look at them after work today, and was hoping that someone might have some advice on how to deal with them. My guess is that the gears in the wipers are just frozen up from years of not being used, but that is simply a guess.
Were the gears greased internally? Can I take them apart and get to the gears on them?
Thanks for the help.
Windshield Wiper Help
- 1969IndianaDodgeMan
- City: Mt Pleasant
Re: Windshield Wiper Help
Gears do have a light grease around them. Motor bushings not sure what was used for them..
You might also want to pull the pivots out of the cowl and
try to free them up with a little light machine oil.
Sometimes, they'll free up a bit which puts less stress on
the motor. I've had some luck doing this in the past. Put a
little light machine oil on and work them by hand.
