Electric choke power
slick
City: Tucson/AZ
Post by slick »
My new carburetor has an electric choke. Im wondering where the best place is to run the power wire from? Thanks
1963 Crewcab
1965 Crewcab
1968 D-100 Longbed
1948 Dodge Panel Truck
1964 Dodge Polara
1957 Shasta
pwadventurer
Re: Electric choke power
Post by pwadventurer »
I think the best place would be the back of instrument panel on the bus bar connected to the fuel gauge. Its "on" with the key run position. Other available engine bay only points would be power to regulator, ballast resistor and horn. make sure horn doesn't work with key off.
oklamopar
City: Midwest City OK
Post by oklamopar »
I tapped into the leading edge (12v side) of the ballast resistor. gave me 12v key on power
Later,
Skip
So here's to you...
slick
City: Tucson/AZ
Post by slick »
Cool, thanks guys
1963 Crewcab
1965 Crewcab
1968 D-100 Longbed
1964 Dodge Polara
1957 Shasta
