What is this extra wire plug for? Mystery!
Posted: Sat Jun 21, 2014 7:09 am
by my5thmopar
I'm redoing the wiring harness and I found this wire. I don't see it in the wiring diagram. Both ends are cut and wrapped back. The entire connector was wrapped to the harness but not connected to anything. It was like someone put in in the harness for a just in case or so it wouldn't get lost. This is weird and I'm not sure what it is for? Everything was working, gauges, under hood and lights.
Re: What is this extra wire plug for? Mystery!
Posted: Sat Jun 21, 2014 6:18 pm
by pwadventurer
Most likely went to the horn relay. See attached link "relay" in electrical section
viewtopic.php?f=21&t=35907
Posted: Sun Jun 22, 2014 9:14 am
by pwadventurer
Attached is a sketch of the horn wiring that might help in rewiring your truck.
Posted: Sun Jun 22, 2014 2:37 pm
by my5thmopar
Thanks for the information. I'll save that diagram for later use. I have to look at the harness again. This truck doesn't have any fuses and I don't think it had a relay. I have a horn coming from a member here. It will probably make more since when I can hook the horn up.
Posted: Sun Jun 22, 2014 7:47 pm
by Hobcobble
my5thmopar wrote:I'm redoing the wiring harness and I found this wire. I don't see it in the wiring diagram. Both ends are cut and wrapped back. The entire connector was wrapped to the harness but not connected to anything. It was like someone put in in the harness for a just in case or so it wouldn't get lost. This is weird and I'm not sure what it is for? Everything was working, gauges, under hood and lights.
If the connector was near your firewall harness bulkhead near
the brake master cylinder, it is likely your horn wiring, as the
horns in early Sweptlines were mounted underneath the hood
near the left hinge.
