why dose dodge do this?
- City: ontario
when i ck for volts at the blue wire that goes from water temp to oil press to fuel gauge I get a pulsating signal at all three. OK IS THERE A REASON WHY IT DOSE THIS? OR IS IT JUST A DODGE THING! O-YES MY GAUGES DO WORK. (SOMETIMES.LOL) I want to put in after market gauges in with a new dash that I am making , but I like to get all the bugs out first. ANY HELP OUT THERE?
Re: why dose dodge do this?
Bad voltage limiter? I replaced it in all my Sweptlines.bigmeangreend200 wrote:when i ck for volts at the blue wire that goes from water temp to oil press to fuel gauge I get a pulsating signal at all three. OK IS THERE A REASON WHY IT DOSE THIS? OR IS IT JUST A DODGE THING! O-YES MY GAUGES DO WORK. (SOMETIMES.LOL) I want to put in after market gauges in with a new dash that I am making , but I like to get all the bugs out first. ANY HELP OUT THERE?
Food for thought.....
viewtopic.php?f=33&t=22961
- City: ontario
IS THAT WHY I GET 12 V AND A ON AND OFF SIGNAL? AND WHERE CAN I FIND 1 TO BUY? THANK YOU
Not following what you're asking here....bigmeangreend200 wrote:IS THAT WHY I GET 12 V AND A ON AND OFF SIGNAL? AND WHERE CAN I FIND 1 TO BUY? THANK YOU
As far as "One to buy"..... maybe someone else on the
board can offer a source. I made my own with components
purchased through Radio Shack & Parts Express.....
- MrMopar
- City: Lompoc
The voltage limiter is a breaker style device that opens and closes as it heats up to regulate the voltage. You will get a on/off signal of about 12 volts, this is normal. The net result is about 5v. Since your gauges do work I do not see a problem.
Most aftermarket gauges are designed to work with the factory senders and generally require 12v to the gauge (read the installation instructions).
Alan
Alan
- City: ontario
Thank You Alan that makes more senses to me. thx 4 the help
What led me to "suspect" the voltage limiter is your statementbigmeangreend200 wrote:Thank You Alan that makes more senses to me. thx 4 the help
regarding the gauges..... that they do work "(sometimes)".
Good luck with your project.
