iginition
okie76
City: broken arrow
iginition
Post by okie76 »
did a rewire on the iginition (atwoods) got it wired up but was wondering why dodge has a ign1 and ign2 wire?????
okie76
City: broken arrow
Re: iginition
Post by okie76 »
ok you guys what is the ign2 wire for i need help :banghead does it go with the ign1 wire ?the system i bought has 1wire set-upfor the iginition do both wires go together ?
Re: iginition
I wish i could help. Did you buy an aftermarket system?
okie76
City: broken arrow
Re: iginition
Post by okie76 »
its atractor ign it only has 1 wire hook up for the ign and the truck has two ign wire so i'm thinking the #2 is for the coil?? but where do i hook it up
elacruze
City: Jensen Beach
Re: iginition
Post by elacruze »
I think ign1 goes to the 'run' circuit, which passes through the ballast resistor and ign2 is the crank bypass circuit, to deliver higher non-resisted voltage during cranking.
