Anybody know were I can get the rubber firewall connectors for both the engine compartment and under dash?
Used ones would be fine.
Ken
Firewall connectors
Firewall connectors
68 W300 "Big John"
Ken--
These are very very hard to find. I've been asking and looking all over. Nobody is making them as repops yet, but somebody I talked to (whose name I forget of course) said they were going to try to come out with some in a year or so.
I finally found some in a salvage yard in Sequin, TX. What year is your truck?
Best of luck,
Joe
Best of luck,
Joe
- MarsMonster
- City: Seattle/WA
If you have a complete donor truck you can remove the wiring from it. I swapped out a 1968 D100 wiring harness for a 1966 D100 harness, in my 1966 D100.
If I recall correctly the ignition assembly uses a different plug on the back of it. (I simply installed the 1968 Dash in my 1966, the ashtray is now in a different spot but I don't smoke)
At any rate you need the entire harness that is under the dash and the harness that goes to the engine and lights.
After swaping out my wiring I now can reference the wiring diagrams to troubleshoot if/when needed. And, most importantly I got rid of all of the splicing that had occured over the life of the truck. And, I had a lot....
