I have a terrible hot start problem with our truck. Cold it starts just fine. Once It has been driven, and turned off, it needs 1/2 to an hour before it wants to start easily again. The truck has a 440 with the stock manifolds on it.
I put a brand new battery in it a few days ago at the auto shop. From arrival to leaving was less than ten minutes. You should have seen the look on the guy's face when the truck struggled to start, as if the new battery was dead!
We have a reman. stock starter on the 440. There is a heat shield wrap on it, but I think it serves to keep heat in.
Has anyone tried a remote mount starter solinoid? I can not get it through my thick head how a remote solinoid would help, when these still needs to be a wire sent down to the hot solinoid on the starter.
Has anyone tried heat shielding sleeves on the wires to/from the starter?
Should I think about a high torque mini starter?
Thanks in advance,
Patrick
Hot start headache
- Veriwide
Hot start headache
Patrick Pitzer
Boone, NC
1971 Adventurer SE "Frankenstein"
Boone, NC
- City: nielsville, mn.
- State: MN
Re: Hot start headache
If all your conections are good, the battery is good, I'd strongly suspect the reman starter. I've seen more than one that hasn't been up to snuff. Load test it when it's cranking and check to see what the specs are for what it's suposed to draw. Dave
tunnel rammed 528 Hemi powered
- City: Elmira, OR
Echo the above. The shield is supposed to keep exhaust heat away from the starter. Too much spark advance can make it hard to start when hot as well.quickd100 wrote:If all your conections are good, the battery is good, I'd strongly suspect the reman starter. I've seen more than one that hasn't been up to snuff. Load test it when it's cranking and check to see what the specs are for what it's suposed to draw.
I agree with the above two posts. When my 440 was fresh (tight) I went to a dual battery set-up for a while. Now that the engine is broken-in somewhat it cranks much easier and I'm back to the original single battery (950 cca) configuration. I do use heavy #0 gauge battery cables though.Ignition timing is real critical in starting a Hot motor and mine still has a tendency to drag while cranking, but I've got headers.Mine seems to want to flood during a hot start also.Since mines a third string vehicle rarely "driven" I don't kill the engine unless its going to have enough time to cooldown.
I have to go along with the same path, advancing the timing is going to slow down the starts as if a bad starter or low battery, I run at least 26 degreees (turned it back some for cold weather starts, for it may be needed to go to work) I have had a "mini" starter, more for the high RPM starts, couldn't imagine using the stock starter, unless I put the motor back to stock, not going to happen also, check and make sure your grounds are clean, just had to replace my grounding bolt yesterday due to rust thought it was the positive cable going out, or bad connection at the relay, but just a bad ground
