speedometer
speedometer
My speedometer on a 69 D100 doesn't work. Is it always the speedometer cable or do I need to buy a used instrument panel?
- Jeffc
Could be ether, did you check to see if cable is even hooked up
at both ends? does it make noise at all when moving? does
the odometer move?
You can pull the cable off the back of the cluster and hang it
below the dash, drive the truck down the driveway and and
see it cable is moving. Then you know which it is.
The center in the cable can be replaced, you don't need the
hole housing, just a good speedo shop.
the odometer move?
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4sp od
Old iron or no iron!
One size does NOT fit all!
62 D100 225 3sp lwb
