electrical wiring
electrical wiring
This is a good one.I have a 1971 d1oo that i bought with no engine.I have installed another engine but cannot figure out the wiring.I have lights turn and brake lights headlights heater and winshield wipers are working instrument lights work The ignition switch wires were disconnected when i got the truck. HELP PLEASE
Dan
Dan
Re: electrical wiring
Need a little more info. Is the original ignition switch still mounted in the dash? There should be a plug with wires attached that plugs on to the rear of the switch. Is this what you mean by the ignition wires being disconnected?
1969 Adventurer W100
- OleRed66
- City: North
- State: UT
Here is a wiring diagram. It's a little hard to read, but it may be just fine. If the truck has original wires, the colors should match up and you should be able to figure it out. Maybe, anyway, it may be a start for you!!
1966 Dodge D100 - Ole Red
1985 Honda Magna - Maggie
Here's a pic of what the rear of your ignition switch should look like. Starting at the "bat" terminal, you should have a number 12 black wire that attaches there, a number 16 red wire on "ign1", a number 14 pink on "ign2" a number 14 orange on "S", and a number 12 light blue on "acc". You should have battery voltage all the time on the wire that attaches to "bat". The "grd" terminal should be grounded. These wires would normally be in a plug that fit the rear of the switch but since that plug isn't there you might look to see if you can find the wires and plug them on individually. You might have to crimp on new terminals. Maybe this will help get you started.Dan61 wrote:no plug just individual wires.What a mess Switch is in the dash
- Attachments
- ignition.jpg (25.13 KiB) Viewed 920 times
might look around here http://www.sweptline.com/tech/electric.html
there may be some helpful information for you
I forgot to add in my earlier post, I would remove the ignition switch so I could see the rear of it and look for any sign that it had been damaged or burned. Look at the connectors and make sure the rivots that hold the tabs are tight. If any are loose it could have over heated at that point and damaged the connector, that might be why the connector is missing. You can check it with an ohm meter while you have it out. It's easy to remove, just unscrew the ring that holds it in the dash. Also the wire colors that I gave came from my FSM which covers up to 70 models. They look to be correct for a 71 but you can verify that with the 71 diagram.
That was a great help.She cranks with the key now.Now i just need to figure our the wiring to the ignition in the engine compartment
Thanks a bunch
Thanks a bunch
souonds like your well on your way to becoming a "SWEPTLINE ELECTRICIAN" that used to be my most hated work, now I've done it so much I know where to go and what to look for, infact I've upgraded with an additional fuse box that has the new fuses and add as I need to
I wouldnt say im an ace yet.I still need to know hopw to hook up the ignition wiring under the hood.The wiring diagrams i have dont seem to match whats in the truck.
Well ive pulled most of my hair out now and still cant get the engine ignition electrical wiring figured out .Any suggestions?
- Ruckus
- City: Stevensville, Montana
I had a similar problem. My truck was gov surplus and had the entire ignition and alternator circuits removed. I got wiring parts from a number of different years at the boneyard and pieced them together. It worked for a while, but then the gremlins started to show and I lost spark... The hard core guys are gonna string me up, but I think the mopar ignition system is junk. There are way too many separate parts and sketchy connections. Add to this the number of revisions they made, and you have a real mess. My solution was to buy a "HEI" replacement distributor and non-ballast resistor coil. I hooked up all TWO wires, and VROOOM, the 318 was back in business! I later found out the quality of the parts I installed were called questionable by some (as if the chinese parts at the local parts store are any different). Time will tell.
78 W200 crewcab, 68 W200, 59 Willys Wagon, 52 Ford F5 Cabover
Im learning a lot here.I didnt know there was such a thing as a non ballast resister coil.Ill be checking that out
How is the wiring going?????? Did you get er done?????
- nfury8
- City: KC, MO
The MSD Blaster coils and the Mopar Blaster coil (4876732 - rebadged MSD, but sometimes cheaper) are all designed to work without a ballast.
