Battery drain
farmhand66css
City: Portsmouth RI
Battery drain
Post by farmhand66css »
I have a question.I have a 66 d100 with a 68 wiring harness. When I turn off the key switch, the gages and radio stay on. If I let the truck sit it drains the battery flat in a matter of a few days. I got stuck the other day and had to get a jump to get home from work. I have been trying to trace it down. I found a 10 Ga red wire from the starter relay to the amp gage. It seems like everything is fed from this. I am thinking of putting a cut off switch and see if it fixes it. Just thought I would post here first and see if someone has some wisdom/ guidance to share
Thanks Matt
Farmhand 66 CSS
66 D100 CSS
65 A100 pop-top van
1978 shortbed stepside
Jeffc
Post by Jeffc »
Matt,
that would work, but I think it is a ingition switch problem.
Orange wire off the relay goes to the switch, at the switch plug
there is a splice, from the orange, were a anouther orange wire
splits off and supplies the buss bar on the back of the gauge set, that is what gives the gauges power.
What is happening here is the switch in not killing the orange wire when
off and that leaves the gauges on. Replacement switchs are
avalable from Napa and I would advise against cutting ether of
the red wires that come off the alt gauge as any bad connections
will give you charging problems.
farmhand66css
City: Portsmouth RI
I thought it might be the switch. I swapped it with one from my parts pile and it still has the same trouble. I will try NAPA and see if I can get a new one. I hate to go and start cutting wires.
Matt :usa
Farmhand 66 CSS
66 D100 CSS
65 A100 pop-top van
