Not charging
- Mavis13
- City: Prescott,AZ
Not charging
Ive got a 68 d100 its not keeping a charge i just had to replace the alt about 3 weeks ago had napa test it 3 times its come back good last week replaced the voltage regulater. the connections are good. But heres the back story. i got a bad alt from a junk yard it had a short in the system which fried my wire from the alt to the gauge inside. i looked and non of the wires are broke so i re taped them.
any ideas on why im not charging? im confused on this one.
- Thomas
- City: Grand Forks
- State: ND
I did the bypass not too long ago. Everything turned out fine, but the voltmeter goes over the top every once in a while...probably my regulator.
Do a search on the MAD wiring if you're going to bypass it.
A new gauge would probably work too. Everything runs through that gauge.
1968 D100 318 727 373
Someday I'll have a whole quonset full of Dodge Trucks....
- Jeffc
Is the gauge moving at all? assuming you did
not do a by-pass and the gauge is not moving>
the gauge may be bad----(not showing + or -
even after starting).
Yes a bad gauge will cause no charge to
go to the battery....
Keith- if you are in town drop by I have a
lot of good amp gauges if you want to take
one with you....
one with you....
- Mavis13
- City: Prescott,AZ
gauge dont work. it moves a tiny bit when the blinker is on but other then that after i fried it it doesnt move. tommorow im goin to have them check the voltage regulater. it should be alright i just bought it last week. i just got new gauges too but havent put them in i got the amp/oil pressure/ temp cluster. if not i hope i can by pass it. thanks again for all the help.
- Jeffc
Just a thought, have you checked the regulator fuse?
will not charge with a bad one (its in the fuse box).....
- Mavis13
- City: Prescott,AZ
so i replaced all fuses installed new gauge and im still not charging. the voltage regulater is brand new. i think i might have hooked up the gauge wrong though one wire goes to the alt and the other to the battery right? the instructions show it goin to the starter solenoid. im confused and i hate wiring things.
- Thomas
- City: Grand Forks
- State: ND
Have you had your battery tested? I went through a charging ordeal not too long ago. I had my battery tested (by someone who apparently was unable to correctly operate the tester)and after replacing several components it turned out my battery was bad and not taking a charge.
One post on the gauge goes to the alt and the other to the relay/battery.
- Jeffc
If gauge moves, it's good.
has to be alt or battery and even new regs
can be bad.
By a cheap volt oms meter if you don't
have one.....engine running....
test large post on alt> should have 13 to 14
volts output,
then test at battery, should be about the
same....
If the above works, your ok on that side
of the system... and the battery is
the problem.....
if not>
wire off the reg (feild wire, green wire) that plugs into
the alt should have the same voltage that
battery has....if less than battery> reg is bad.
If volts are right there, then it's the alt
that is not putting out....
A real easy test, pull the + cable off when running..
if engine dies, it's the battery that is bad,,,,
can be bad.
volts output,
same....
the problem.....
if not>
- Rusty_Quarters
- City: Madera
Thats the way I always heard it, if the engine dies with the + disconnected your alt or reg not charging. Try the jumper on the back of Volt meter, this is fairly common problem, I had to do mine a couple of weeks back, that was the solution. My gauge would move slightly ever now and then also, so when I hooked up my new gauges I bypassed the old one all together, and it works fine.
Charging
On the pre-computorized engines if you have the engine runnin and pull off the + and it keep running that means the Altenator and regulator are fine, it cannot runn off the battery with the + disconected. On our trucks once the engine is started the altenator recharges the battery within the first 2 minutes, and supplies the vehicle with all the electrical needs until shut off, in the past, when checking the altenator one would start the vehicle and then remove the + if the vehicle stops runnin that means the altenator isn't workin
- Mavis13
- City: Prescott,AZ
ok heres a update. i rewired the burnt wire i charged fine for about 2 weeks then the alternater went out. so went back up to napa got another alternater same results 2 weeks later alternater went out again. so this time i went up to car quest i know a guy up there so after i left there he searched his books and what not and found the exact one i needed and also found out napa has been selling me a mid 90s alt. he also tested my charging system and its all complete so hopfully no more problems with that. thanks all for your help.
