Constant 12v for new Radio
fosterfarm
City: Gilroy
Post by fosterfarm »
Hello,
I got a Retrosound stereo i'm trying to install and it needs 12V of constant power from the battery along with 12V ignition/ACC. Reference here: https://www.retromanufacturing.com/page ... your-radio
Has anyone installed a new stereo and has guidance here?
Thanks!
MadMC63
City: Rome
Re: Constant 12v for new Radio
Post by MadMC63 »
12V constant is typically power for the devices memory ( programed presets) and 12V switched is for operational power, on and off with the ignition switch, keyed. If you poke around the fuse box you should find both.
fosterfarm
City: Gilroy
MadMC63 wrote:12V constant is typically power for the devices memory ( programed presets) and 12V switched is for operational power, on and off with the ignition switch, keyed. If you poke around the fuse box you should find both.
Thanks! I have looked at the fuse diagram (here: download/file.php?id=33268&mode=view) and can't figure out which is which. I'm assuming "Radio 6A" is the switched 12V. Which location has constant 12V?
MadMC63
City: Rome
Post by MadMC63 »
I think an industry standard is yellow equals 12V constant (memory) and red equals 12V switched power.
pwadventurer
Post by pwadventurer »
fosterfarm wrote:Thanks! I have looked at the fuse diagram (here: download/file.php?id=33268&mode=view) and can't figure out which is which. I'm assuming "Radio 6A" is the switched 12V. Which location has constant 12V?
4-way flasher/ cigar lighter is a constant hot on your fuse block.
pwadventurer wrote:
Tue Jan 23, 2018 6:41 pm
[/quote]
A light tester will determine that. Easy to figure that one out.
The ACC terminal on the ign switch is "switched 12V", the + terminal on the ign switch is hot 12V all the time. Too simple!
