Reverse lights not working
71swept777
City: Hudson
State: WI
Post by 71swept777 »
Hey there,
Have a 71 Dodge D100. When purchased it had the 3 on the tree removed and a 3 speed on the floor put in. I fixed the speedometer not working issue, but don't have reverse lights. Is there something "buried" in the steering column that needs to be jury rigged - or? Thanks in advance.
WASH YOUR HANDS. Work hard & BE NICE TO PEOPLE.
Re: Reverse lights not working
The reverse light switch is usually on the transmission, not the column.
71swept777
City: Hudson
State: WI
Right. So I need to find those reverse wires and wire them to the reverse switch on the new trans?
Yes. And its possible that the previous owner removed those wires or just didn't plug them back in. I'm assuming only the shifter was changed & the truck still has same transmission, correct?
71swept777
City: Hudson
State: WI
Correct - original trans. I will take a look - thanks!
marklein
City: Red Deer
Post by marklein »
It's the 2 outer wires on the neutral safety switch. One has 12 volts+, the other goes to tye backup lights. The center wire is the neutral safety.
Caliswept
City: Winchester
Post by Caliswept »
saw this post and its right up my alley....
my neutral safety switch has 3 prongs also
1 Is reverse lights and now work...
I reversed traced the wires and found out that 1 black wire is not connected... I cant figure out where it goes to...
so if anyone has retraced them back, can u please let me know...
Caliswept
City: Winchester
Post by Caliswept »
where does the center one go connected if u trace it back to the wiring harness?
pwadventurer
Post by pwadventurer »
Caliswept wrote:where does the center one go connected if u trace it back to the wiring harness?
My guess would be starter relay, ground wire
MadMC63
City: Rome
Post by MadMC63 »
I think a good question to ask is will it start in gear?
