I can't find them locally. Are they availble anywhere online?
Thanks!
Darrell
Rear drums D200 1965 - available new anywhere?
- wideblock
- City: las cruces nm
- State: NM
i just bought drums for my 65 d200 at carquest. got them about 3 weeks ago. i think they were 80-85 each ill have to go back and check the reciept.
- wideblock
- State: NM
mine came from checker auto parts. ill try and give them a call to get the number, my reciept has seen better days and i cant tell from it. but, it was the drum only. youll have to get new studs, and take the new drum and studs, and the old drum/hub assembly to a machine shop and have them swapped over. then turn the drum, always turn the drum after this swap to get it centered with the hub. if you skip this part, your brakes are liable to pulse as you hit them.
- wideblock
- State: NM
the one i put on my truck was a 12 1/8x2 speced in the book as a 69 modle. checker part number 2949 book out at $96.99 each on order of course. i compared this to the 65 that was in the crew, the 66 thats under my trailer and the 69 dana 60 thats under the truck now, they are all the same.
