Power Rack for straight axle trucks
Well through last year, I had at one point entertained the idea of putting a Rack on the straight axle for power steering, I don't know if the company read my post but they did it go to http://www.nolimit.net click on powersteering and here is my idea exactly now in production
power steering
and some said it couldn't be done
- TedWitt
- City: Magnolia
Ride Quality
I put 235/75/15 radials on mine and run them at 32psi, the pressure is supposed to be 35psi. The only think is it's hard to turn going really slow or sitting still, parking is a bugger, but it rides good. That's why I'm thinking of power rack n pinion steering.
- fosh69
- City: Firestone
I'm glad they finally got it done. I've been dying to know what the cost would be... earlier this year I read an article on a 195? Ford that the owner wanted to keep the straight axle and nolimit was doing the custom build...(in one of the classic truck mags). Anyway... I emailed nolimit and asked them about kits for other straight axle trucks and at that time they had their kit available for the fords, but nothing else. Soon after that, the kit went into "available soon" satus and now it seems to be for all straight axle trucks. I'm thinking they got bombarded with requests like mine and had to go back to the drawing board, because on their inital email reply they told me they probably wouldn't do anything for Dodge trucks... I replied saying I'd do the R&D myself and figure out how to use their current kit (at the time) on my Dodge axle... of course I didn't get very far, but I was hoping there would be enough people requesting a universal kit. Now that it's here... my truck is gonna get it after I have Dave Mann in Phx drop my axle... at least that's my plan
Sure, it may cost more than an IFS, but hey... I want R&P on a straight axle.
yes the rack will mount were you currently have your drag link and bolt up to the axle, then they have the telescope tube (just like in the 2000-up Mustangs) so when your doing your drive it moves with the axle. Yes I read your post, I didn't respond for a year or so ago when I brought up the Rack, it recieved alot of negativity, saying it wouldn't work, so instead of getting a big debate going I just let it go
The airbags can be put on the front, some of the kits would eliminate the leafs and use like a 4 link system, with the airbags no need for leafs anymore, they have more load capacity than the leafs, as far as the ride quality??? never ridden in a just bag, truck to see, but everyone claims the ride is better???
I don't see how the rack, and drop axle is close or more than the IFS???? the rack $649 and drop $480.00 and the least exspensive Mustang II is 1600.00, plus you have to buy rims that are 1" offset, so and a few hundred more. the rack and drop is still cheaper. plus you could get a usuable rack at the yard.
Would any of these trucks have an axle that is about the same as ours?RH62 wrote:i dont know what you guys are talking about.... dodge is not one of the trucks that they list a kit for at nolimit. Available for: '47-54 cheby Pickup; '55-59 cheby Pickup; '48-52 ferd F-1; '53-56 ferd F-100; '57-60 ferd F-100
In the magazine with BigDad's truck they install a drop axle in a late 50s Chevrolet. I don't see why something like this wouldn't work in a Sweptline. The parts would be cheaper for these more popular applications too.
Power Rack
Well we already know a 78 ThunderBird rack will work for this truck has one and it has the exact same wheel width as the regular draglink, I first got the idea when I saw the powerrack from a Sundance laying on the shop floor, had the worker measure it for me, I couldn't believe it looked as the exact length of our existing drag link, it came out to 48 1/2 with no tierod ends, If your not into doing something that no one else has done, like if you need direction and un-insprired to do something, then don't try it. If you like something because it comes in a kit, then wait and do it another way, cause you've got to be able to plan it and see it in your mind, other than that wait and someone will come out with a kit with directions.
Re: Power Rack
well said! Im thinking the DIGDOUG way is a pretty good option also, Mid 80's Ford truck powerboxMountainMoparRobin wrote: If your not into doing something that no one else has done, like if you need direction and un-insprired to do something, then don't try it. If you like something because it comes in a kit, then wait and do it another way, cause you've got to be able to plan it and see it in your mind, other than that wait and someone will come out with a kit with directions.
its probably about the same amount of work. Wouldnt need the telescoping shaft either.
Rack
No CLIFF that truck still has the Sweptline frame, but, but, he did just as I would if I was going to do IFS, keep our frame and just weld the needed parts to it, just like the "C" body cars-there frame is the exact width, there only difference is they have IFS.
That truck used the 78 T bird rack because very little done to make the tie rod ends work and the tire to tire width is the same as stock
There are a few powersteering options now, I'm going to power steering and fliping the axle and shortening the pitman arm so no "bumpsteer" and Disc brakes
- RH62
i emailed no limit and asked if they had a kit for my d100.... heres what i got.
Rich,
I am sorry, we do not make anything for a Dodge.
Good Luck on your project.
NLE
just figures.....
Cliff the setup your talking about is a kit. That is the protech kit that they no longer make.
Rich,
NLE
just figures.....
Not everyone that has a dodge sweptline has fabrication or mechanical experiance. That doesnt mean that they dont want power steering! Who woudlnt want a profesionaly fabricated setup for there truck?If your not into doing something that no one else has done, like if you need direction and un-insprired to do something, then don't try it. If you like something because it comes in a kit, then wait and do it another way, cause you've got to be able to plan it and see it in your mind, other than that wait and someone will come out with a kit with directions.
Posted: Thu Oct 26, 2006 5:45 am Post subject: Re: Power Rack
well said! Im thinking the DIGDOUG way is a pretty good option also, Mid 80's ferd truck powerbox
Axle
RH62,
I put that there because this swap is going to take the measure and fabrication to make it work, one could take what NoLimit has and make it work, wait for awhile longer maybe by February I will have the Toyota box mounted, its the easiest of all, and an adapter plate, along with a pitman arm, and it will just bolt in
