Dave Mann http://www.roadsters.com/axles/
Roadsters.com
1645 E. Willetta St.
Phoenix, AZ 85006
(602) 233-8400 weekdays
davemann@roadsters.com
has only delt with tis guy before?
430 bucks gets an axel drop up to 4inches i want to go old school with my other truck. or may be some one could check him out?
john
drop straight axles
- hotrodjohn68
Im ready to do this. Im picking up a front axle and sway bar "donated from the swepty bone yard" friday and i was about ready to call this guy to ask some questions. Im concerned about the steering geometry...Im guessing its up to me to get that part of it figured out...I think I know what will fix the problem...Anyway I'll call him in a day or so. Ill let you know whats up.
Cliff
Cliff
- Shiny
- City: bc
Dave has a really good rep.
I've never heard a complaint bout him.
Hes been on the HAMB a long time and is well respected.
I have a jig setup to drop early ford axles in my shop.I'm gonna see if I can adapt it to drop sweptline axles.Won't know for a while though as were in the middle of building my new shop.....Shiny
"daddy smells like grinder" -lil Ember (my 4yo daughter)
- Shiny
- City: bc
Yeah but we all got gas axes right!
Usually I heat and bend the steering arms down so they won't interfere.(I'm not getting into a debate on this either )
And I know guys wanna know about bumpsteer too.
Well whether your gonna put a dropped axle in,take some leafes out or flip the axle bumpsteer will factor in.One of the easier ways to fix this is to make your draglink into a 'Z'.....Shiny
Pretty extreme,just to get a few inches.
What about cutting the frame and shoving the spring hangers up farther to get those three inches(then boxing it in)? A lot easier than trying to figure out how to bend an axle and keep the holes the same-I could do it,but why?(build a jig,heat,then press).
I like the holes though. Now that's cool. I was planning on that,but wow,what time and effort. I was going to torch 'em,then thought,no,too much heat. Plasma,but it'd have to be a good sized plasma cutter to get through it cleanly-so,no holes. I'm not taking it apart just to drill holes. 1/4 mile E/T is where I live anyway and a few holes is not going to transfer very much weight. But the front will go down at least two inches real soon. Look for pics.
There's no replacement for displacement
http://img.photobucket.com/albums/0803/ ... k440-3.jpg
http://img.photobucket.com/albums/0803/ ... ckk440.jpg
drop
you can also take all the arch out of the springs, or buy drop springs, http://www.mopar.com has springs with 1" positive arch for $92.00 need to confirm if they will fit. Shaun I would be interested to see your drop when you get pictures
Mountain, it seems like there is always something to do. I hope to have it done soon,because I need to get the underneath totally scraped,wirebrushed,wiped with a special rust concoction and then undercoat applied. I'd like to be done with the underside soon.
Be talkin to you all
Shaun
Shaun
