k-frame?
spikekid999
City: sticks of WI
k-frame?
Post by spikekid999 »
has ne1 put a k-frame in there truck b4?i wanna put a 80s chrysler 5th avenue f-frame under the front but i wanna no if itll fit or not and what u have 2 do
craig
1973 dodge dart (project Money Eater[urlhttp://www.cardomain.com/ride/2934209[/url]
1987 Chrysler Fifth avenue (Training Day Chrysler)[urlhttp://www.cardomain.com/ride/2647481[/url]
Seabee
City: Houston
Post by Seabee »
I know of at least one Aspen/Volare swap. Do some searching in the threads and it'll turn up. I personally wouldn't go that route; IFS is a VERY common topic - most common is grafting of a later model frame, some (Baddeeds) have even fabbed up mounts for Corvette front gear.
Yeah just search the forums under suspension. You should find all the info you need. :Thumbsup
spikekid999
City: sticks of WI
well i aint got the $ for a IFS and i dont want 2 do alot of fabing w/ cutting the frame n everything but i do have a k-frame out of a 88 dodge diplomate squad car so ya
craig
Here is one way to do it.
http://sweptline.org/modules.php?name=F ... ebad8ac161
There was another truck where it was done slightly different with cutouts in the frame.
geno440
Post by geno440 »
I am presently putting a 86 New Yorker K in my 68 Sweptline.
I am about 1/3 of the way there.
It looks like it will work with some work.
I'll post some pics and the process when I get finished.
OregonDodgeboy
City: Nampa, Idaho
Post by OregonDodgeboy »
Three words; Frame swap man! :Thumbsup Much easier than you think.
Refer to these links:
http://sweptline.org/modules.php?name=F ... 40431b8358
http://www.sweptline.org/modules.php?na ... pic&t=7292
Or just search through the suspention threads like previously mentioned.
Jeff Easterbrook
67 W200 440/4-sp. Resting
76 IH Scout II
81 MB 240D
spikekid999
City: sticks of WI
i dont wanna cut up my frame. thats the one thing i WONT ct cuz then ill have to try and get it striaght and it will prolly loose some of its strength.
craig
spikekid999 wrote:i dont wanna cut up my frame. thats the one thing i WONT ct cuz then ill have to try and get it striaght and it will prolly loose some of its strength.
With the K-frame you will probably have to do some cutting or at least notching.
For the money the Aerostar swap might be the best if you want to keep your frame. Nobody has much information on it though and you might not want Ford parts on your truck either.
The other cheap method without cutting the frame would be to swap it on to a 72-93 truck frame. The wheelbase is 3 inches longer on these trucks but you could move the rear axle and make it work without cutting the frame.
With the amount of work you are going to be doing to your truck I'm sure you can make something work.
What the hell. I cant even say f-o-r-d. I don't believe in sensorship.
spikekid999
City: sticks of WI
ya i dont like sensorship either lol. i know with the k-frame i would have to do some knoching and i already no how about im going to strenthin it back up i just dont wanna do any major cutting on it
craig
OregonDodgeboy
City: Nampa, Idaho
That's why the frame swap works so well. The front cab mount is the only difference really. They are longer, so you gotta use 'em, the Swepty cab isn't designed for the short mounts. You just remove the rivets from inside the frame and reuse the front cab mounts. The rears have to be moved, but that is even easier because you can move them once the cab is where you want it, meaning no measuring! :Thumbsup
The most "fab work" you'll do is in the steering. If you want fast and easy, you can reuse the later steering column. The length is perfect. You just have to notch the firewall, as the steering box on later trucks is out front. The other option (and the one I'm looking at when mine gets redone) is to use the stock column, and make an intermediate shaft with Boergson joints to connect the two.
Besides, it makes getting chassis parts easier in the future. No need to make a list of what car gave up what part. :lol:
Jeff Easterbrook
76 IH Scout II
81 MB 240D
