Wheel alignment, what should the settings be?
Big_G
Post by Big_G »
I'll be replacing the tie rod ends, and I was wondering if I could do a rough wheel alignment. How much difference should there be from the front measurement and the rear measurement of the front tire? Is that in the repair CD?
Wayne
JimE
City: Glendale,
Post by JimE »
Wayne are you planning on making to Willcox on Oct. 7th for the Rex Allen days Sweptline Rally and Q? Here is your measurement +/- 1/4" I think. I have done this 3 times with my wife holding 1 end of the tape. Have run them into an alignment shop and it is within specs, 3rd one is pending. Jim
03 Hemi Ram 2500
Big_G
Post by Big_G »
Thanks for the info Jim. Yes, I plan on attending. I look forward to meeting you and many of the others.
Wayne
wideblock
City: las cruces nm
State: NM
Post by wideblock »
my dodge book says dead zero to 1/8" as the alignment for toe in to get the easiest steering effort and least amount of tire wear. im running 1/4" because its giving a better raod feel, and the steering effort doesnt seem to be effected. i have driven the truck around 4800 miles on the new tires, and there is no sign at all of any odd tire wear. 2500 of those miles were in a one week period cruising I-10. so i would imagine something would have shown by now.
JimE
City: Glendale,
Post by JimE »
wideblock wrote:my dodge book says dead zero to 1/8" as the alignment for toe in to get the easiest steering effort and least amount of tire wear. im running 1/4" because its giving a better raod feel, and the steering effort doesnt seem to be effected. i have driven the truck around 4800 miles on the new tires, and there is no sign at all of any odd tire wear. 2500 of those miles were in a one week period cruising I-10. so i would imagine something would have shown by now.
And to think I just paid 49.95 to reassure what I already knew. But its peace of mind $$ well spent. Jim
03 Hemi Ram 2500
front end alignment
That is the one thing I really like about the straight axle, actually 2 things I like, #1. is the fact when the axle is aligned it holds the alignment forever! I had mine done in 1990 and its hold true every since. #2. Less moving parts, which translate to less money spent on replacing parts. THIS IS HUGE :Thumbsup
mopar400
City: Bloomingdale, GA
Post by mopar400 »
I found a usefull tip when setting the toe. Before setting, place a plastic garbage bag under each front wheel. This allows the tires to move and acts like a turn plate. If not your setting will change when the vehicle is moved. Mopar400
70 Challenger 506hp 440, 727, 11.29@120mph
1965 Fury II(in pieces)
JimE
City: Glendale,
Post by JimE »
I have always done mine up on a jack or jackstands, but that is useful advice. Jim
03 Hemi Ram 2500
