Coil over shocks
Coil over shocks
I remember one time that someone said if you want to increase capacity, to add coil over shocks on the rear. I believe Trey said it. What Im asking is, has anyone done this, and what type and # shocks they used. This is going on 67' d200. Thanks!
1974 Dodge D600 318 5+2
2003 Ram 2500 Cummins HO
- wideblock
- City: las cruces nm
- State: NM
i have done it on numerous trucks, but none of my swepts have gotten them yet. i always used monroe, they are a great shock. they do increase capacity, but not by much more then 500 pounds. what they do accomplish is better load control. you wont sway as much, or bounce as much, or run the risk of bottoming out near as easy with them on there. makes hauling a load safer. only draw back is empty they will raise the back end of the truck up about 2 inches.
Trey
1965 CSS Utiline.
ex trucks:
70 D100
66 d100
66 d100
67 d100
69 d100
69 d200 crew cab
65 crew cab
66 d100
66 d100
1965 CSS Utiline.
ex trucks:
70 D100
66 d100
66 d100
67 d100
69 d100
69 d200 crew cab
65 crew cab
66 d100
66 d100
