Pinion Snubber on a Swept!
- mopar400
- City: Bloomingdale, GA
This was one of my projects last week. I bolted on a pinion snubber and made a support for it to contact out of 2"X4" tubing.This was a fairly easy install and the only modification to the truck was drilling two holes in the shock crossmember. I haven't been able to test it on a dragstrip but it definetly eliminated my wheel hop on burnouts! Mopar400
70 Challenger 506hp 440, 727, 11.29@120mph
1965 Fury II(in pieces)
- motomatt383
- City: Durham, NC
- State: NC
very cool, i've looked at mine but hadn't done it yet.
matt
matt
'70 Roadrunner
'40 Dodge coupe
'70 Roadrunner
'40 Dodge coupe
- City: Lawton
Rancho suspension makes a kicker shock system that does about the same thing. I think a combonation of the two plus new springs should do the trick.
Life should NOT be a journey to the grave with the intention of arriving safely with a well preserved body, but rather to skid in sideways, beer in one hand,cigar in the other, body thoroughly used up, totally worn out and screaming,"what a ride"
pinion snubber
Since I've moved my gas tank behing the rear wheels I've not had a problem with traction, but then again I'm only runnin small jets in the carb, Whats the draw back on pinion snubber??
- mopar400
Re: pinion snubber
If you have it adjusted up within a 1/2" of touching it hits on bumps while driving. It makes the ride a little stiffer. I have been just running it on the bottom position and moving it up one hole if I'm going to scorch the hides! Mopar400MountainMoparRobin wrote:Since I've moved my gas tank behing the rear wheels I've not had a problem with traction, but then again I'm only runnin small jets in the carb, Whats the draw back on pinion snubber??
- wideblock
- City: las cruces nm
- State: NM
the biggest draw back of the snubber on a truck is its in the way if you carry a load. other wise, they work great. i had one on my 69 charger, loved it. when your at the light, and gas it while on the brake, it made the car haunch up like its all bad @#%. LOLOL!
snubber
Thanks ,
did you buy the snubber??? where/??
- Seabee
- City: Houston
MP part available from good 'ol Summit;
http://store.summitracing.com/partdetai ... toview=sku
- mopar400
Re: snubber
[quote="MountainMoparRobin"]Thanks :salut,
did you buy the snubber??? where/??[/quote]
I took it off my Challenger. I have had it and used it on the car for about 10 years. It came initially from summit racing like seabee showed. I've also seen them on ebay. It wouldn't be hard to make if you had one of the factory pads of a car diff., weld on some tubing and put a bump stop on top. Mopar400
