D200 Wheel & Tire Size
I'm looking for replacement wheels/tires for a 1970 D200. I was thinking of the American Racing AR-23. Will a 16" x 8" wheel with 4 1/2" backspacing and 235/70 -16 tires work? If not, any suggestions on where to find 8 lug wheels? Thanks for the help!
- wideblock
- City: las cruces nm
- State: NM
i think the backspace you mentioned is too much for the front. it will rub the steering arm in a tight turn or the tie rod when installed. you can get away with 4" and a narrow tire up front. i believe the standard off the shefl back space of a 16x8 is 3.75 to 4" of back space. wich works fine with up to a 245/75/16. mine has 16x8's up front right now, when i have the wheels off for polishing, ill measure the back space. they have 235/85/16 tires, and if i had even 1/4 inch more backspace, they would be rubbing my tie rods right now. as far as the back goes, i have a 16.5x10 out back with 33x12.5x16.5 tires. they fit great with no rubs, even fully loaded.
- menefreghista762
- City: Baytown
Trey,
Did you ever get a measurement on front wheel backspacing?
I have a D200 and need to fit new tires and wheels on it. Dodge and Ford are the only bolt on swaps for me on 8 lug?
Merry Christmas!
Merry Christmas!
[color=#FF0000]"Catfish"
64 W100 \6, np420, 4.10 SG, stick_WAR WAGON!!!
65 D200 318ci, stick-SOLD!
67 D200 318c, stick-SOLD!
"Once you pull the pin, Mr. Hand Grenade is no longer your friend[/color]
- wideblock
- State: NM
your in baytown??? kick @#%, im in league city right now seeing the family for xmas. boy did i used to run havoc in baytown, LOL...i never did get a backspace measurement, still havent taken the wheels off to get polished. but, i do have a pair of 16x7 rims with the wrong backspace sitting at the house. remind me with a PM around tuesday and ill get you the measurment.
you guys ought to come to the texas ralley in june
