69 w100 wheel cylinder
Posted: Sat Nov 04, 2023 6:49 pm
by Levigator
Swapping out the driver steer w/c with a Napa part...the line is leaking all around the line at the w/c. Seems like the bore/flare mating surface is deeper on the Napa piece which isn't allowing the flare to sandwich correctly even though the fitting is tight...there's still 1/16+ play in hard line. I can't compare as I dropped the original in the garbage at Napa today. I'll call in the am and see if it's still there but has anyone experienced this? Napa # 36018. Thanks, James
Re: 69 w100 wheel cylinder
Posted: Sat Nov 04, 2023 9:44 pm
by nutz
make sure that there is a cone in the wheel cylinder ...sad but some of the stuff is crap now
if there is a cone then might need longer flare nuts ....if no cone then they are wrong ...bubble flare
i just got my oil pan gasket ..felpro...f-n junk ...i remember when felpro was good stuff was cut too short had to seal with a lot of extra gasket sealer
Posted: Sun Nov 05, 2023 10:35 am
by Levigator
For sure, generally have good luck with parts.. hoping this is just a fluke or else I have to find different brand.... I'll peep down inside the cylinder, thx
Posted: Sun Nov 05, 2023 5:48 pm
by Levigator
New part is bubble flare...bought a 6" line and cut the 45° off and reflared it..which gave me a reason to use my new indexing flaring tool!!
Posted: Sun Nov 05, 2023 9:31 pm
by nutz
they make an addaptor bubble to double ....
but i just flare my own
