67 W200 locking hubs
johndorn
City: Hilbert
State: WI
Post by johndorn »
I have just replaced one of my manual locking hubs on my 67 W200 because it blew apart when I was plowing snow, most likely because several of the bolts fell out or were sheared off on the hub. I took it apart about a month ago and now I am not sure where the large spring goes that came out of the assembly. It seems to work fine without the spring, so I am not sure if it is needed with the new hub. Can anyone tell me where it goes? I am trying to avoid ripping the drivers side apart to check.
martincom
City: Five Points
Re: 67 W200 locking hubs
Post by martincom »
Here is an excerpt from the '69 - '70 Service Manual. I'm not sure if it is the same. Quality re-prints of the factory service manual are readily available at a reasonable price. It'll be the best investment you can make in your truck.
martincom wrote:
Sat Jan 21, 2023 9:14 am
Wrong Hub illustration. That is for the W100 internal style 69 to 71 front axle. The 66 W100 is very different.
johndorn
City: Hilbert
State: WI
Post by johndorn »
Thank you for the post. It appears I will need to take the hub back apart and add the spring back in.
