Hello, My truck came with 17x7 rims with 235/65r17 tires mounted on it from the previous owner, I want a more original look, I picked up a set of original KH 15x6.5 steelies. I've been looking at what tire size I'm gonna run, I'm looking for all season road tires, no all terrains or anything unique. Size wise I narrowed it down to 235/75r15 OR 265/75r15. 235's are gonna virtually be the same tire as the one currently on it (235/65r17) it's just for a 15" rim instead. Would a 265 have a big sidewall stickin out on a 6.5" rim? Would they even clear the wheel wells? Maybe there's other sizes some of you may recommend that I might go with instead.
Thank you - LB
New Tires, What Size am I Better off with?
- 64D100Poly
- City: Vancouver
-1961 Dodge Dart Pioneer
-1968 Barracuda Formula S
OO\===/OO
OO\===/OO
Re: New Tires, What Size am I Better off with?
Found a nice Tire Size Comparison Calculator
https://tiresize.com/comparison/
uh, yes... just over an inch wider... is that 'big'?Would a 265 have a big sidewall stickin out on a 6.5" rim?
Don't know, maybe also be concerned about tire rubbing the steering arm at full crank left turn.Would they even clear the wheel wells?
- City: Fort Collins
On my '67 D100, the 235/75R15 tires look right to my eye and perform extremely well with no interference with any components. I run the Kumho MT51 on the rear axle as it's the only D rated tire I found in this size and I tend to overload the truck on occasion. I've found the all around traction to be excellent with this tire as well: great on unimproved dirt, good on dirt road, good in snow, and good on pavement, wet or dry.
Ken
Ken
Why did you pick those 2 sizes?
You are right about the 235/75R15 being pretty close in size to what you have now. If you want to go wider, then a 255/70R15 is also similar to what you have now, but nearly an inch wider. If the wheels are only 6.5" wide, I'm not sure you want to run a 265 tire or even a 255.
I believe someone said a 31x10.5 tire would fit and not rub anything on a stock sweptline.
31 10.50 is about the next size bigger then a 235/75
but should be on min. 8" rim 235/75 on a 6.5 is pushing it thinking 225/75 is optimal
i'm sure there is a chart some where
- 64D100Poly
- City: Vancouver
I appreciate the reply's, think I'm gonna go with 235/75's, it's a common size and gives me a lot of choices
OO\===/OO
OO\===/OO
- City: Binghamton
- State: NY
I ran 30x9.50x15 tires on my Dodge Dakota. As I remember they were slightly taller than the 31x10.50x15 tires on a ford truck I had at the time. Both trucks had 8 inch wide rims.soopernaut wrote: ↑Tue Dec 13, 2022 6:30 amThere are some sizes between those, but they aren't very common sizes. Most 31 inch tires are actually smaller than 31 inches.
I was always curious why.
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
