I’m looking to add power brakes to my 65 swept.
It originally had the small booster under the floor with a single pot master cylinder. I would like to have a dual reservoir with the booster on the firewall.
The truck has disc brakes in front and drums in the rear. Both axles are from a 1980 one ton dodge.
What kind of ideas does everyone have.
Power brakes
- City: Binghamton
- State: NY
Power brakes
Late 65 w 200.
Factory LU-2 winch.
440 repower in the works
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
- martincom
- City: Five Points
Re: Power brakes
I'm going to assume you have a hydraulic clutch. If so, there likely will be a clearance issue. I believe the RamMan has addressed this and offers a kit with offset brackets. He's a little pricey, but he knows his stuff and offers quality products. He does a lot of YouTube videos. You may have to phone him for specifics: https://therammaninc.com/
- City: Binghamton
- State: NY
Re: Power brakes
I do have a hyd. clutch also it will have a 440. I met Ram man in Carlisle a few years back and planning to check with him this year at the mopar show. I’m still open to all suggestions. Doing my own fab work isn’t an issue.
Late 65 w 200.
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Factory LU-2 winch.
60 d100
383 with 727
4 wheel disc
3.73 geared rear
Re: Power brakes
I used a power brake booster from an early 70's Dodge Dart A Body back in the day. No clearance issues with clutch master cyl. Kits are available that will work with clutch master. I did fabricate the arm from pedal to bell crank pivot.
https://www.mpbrakes.com/booster-master ... 0BD5FB51CB
