Parking brake handle and cable setup.
mstrader77
City: Salem
Post by mstrader77 »
I'm working on a 1967 D100. What keeps the front parking cable housing from being pulled through the firewall grommet when the parking brake is engaged? I feel there should be a bracket on the end of the handle to hold the end of the cable housing stationary.
Re: Parking brake handle and cable setup.
The "grommet" is integral to the cable housing and won't fit thru the hole in the firewall.
Wildergarten
City: Los Gatos
Post by Wildergarten »
mstrader77 wrote:
Thu Dec 30, 2021 11:20 pm
Did you take it off? Are you sure you have all the parts?
If I recall correctly, the the end of the cable housing is clamped to the bracket that bolts to the inside of the cowling and the bottom of the dash. Once that opposing axial compression is retained at the end of the housing, it can no longer impart axial force to anything else. The grommet doesn't stop anything but leakage.
mstrader77
City: Salem
I bought the truck as a no motor/trans project, so some things are a bit of a puzzle and may have been incomplete. I took photos when I took it apart, but am missing one for the parking brake. Would anyone happen to have a photo of this area? I'll try to add some photos of what I have.
mstrader77
City: Salem
All my pictures are too big to post. I ended up welding a plate to the end of one side of the parking brake handle, drilled a hole to match the small diameter of the cable end, and cut a groove to the hole for the cable. Works great.
FWIW Dodge medium duty trucks continued to use the handle brake through the end of the run in 1977.
Red383
City: Fort Loramie
State: OH
Post by Red383 »
Here is a picture. There is a small tab on the bracket that stops the cable housing from being pulled into the cab of the truck.
I think this is what you are asking.
Red383
City: Fort Loramie
State: OH
Post by Red383 »
Here is another pick from the top side of a spare handle I have.
Aaron
mstrader77
City: Salem
Thanks for the photo. My cable end seems slightly different. I finally figured out how to get my pictures small enough to post. This is what I ended up doing and it works well.
