Best king pin set
- City: Winter Park
Best king pin set
'63 d100, one is loose. I see rockauto has Moog 8453B., I have the 2500# axle.
- hmaynord
- City: fairhope
Re: Best king pin set
there are 2 comments about ball bearing king pins in this thread:
viewtopic.php?p=306362#p306362
the 2 earliest posts dated Fri Jan 03, 2020.
don't know if they are available for your application.
harris
driving it since 12/03/71
I would definitely urge ball bearings and bronze bushings. It improved the steering feel for my 68 D100.
- City: Winter Park
I ended up buying the Moog with bearings/brass bushings, same that is in it, came apart easy.
- City: West palm beach
Is that a ball bearing set, or stacked washer bearing? I'm about to do mine on my 67 d200, ordered a set by AC Delco a long while back and, while the bushings and ball bearings appear correct, the king pins are thinner than what was there originally, so I'm going to probably be ordering a different set.
Don't have the AC Delco on with me, but will post it tonight .
I replied to your inquiry on spindle bolt size just a short time ago
"Every time you hit the brakes, you put your life in the hands of your feet"
- City: Winter Park
It's got the brass bearing stacked washer, the one I replaced had the ball bearing. I didn't see an option for the ball bearing, but if need be I do have part #'s on the old bearings.67LSD200 wrote: ↑Tue Mar 23, 2021 1:01 pmIs that a ball bearing set, or stacked washer bearing? I'm about to do mine on my 67 d200, ordered a set by AC Delco a long while back and, while the bushings and ball bearings appear correct, the king pins are thinner than what was there originally, so I'm going to probably be ordering a different set.
- 64D100Poly
- City: Vancouver
I got the set made by Moog with bronze bushings, do be warned that you have to ream bronze bushings to size with a reamer, plastic ones you don't but aren't as durable. I didn't know this at the time and spent 4 hours and went through 3 wheel cylinder hones slowly boring out the bronze..
-1961 Dodge Dart Pioneer
-1968 Barracuda Formula S
OO\===/OO
OO\===/OO
