Polyurethane Front & Rear Leaf Spring Bushings
RKT
City: Morgan Hill
Post by RKT »
Hello,
I've looked through the site and would like to confirm that the following Energy Suspension's part numbers will work on my 1965 D100 2wd Short Bed?
Front Leaf Spring Bushings - Spring Only - 1 Inch eye only
Manufacturer: Energy Suspension
Part Number: 5.2102
Rear Leaf Spring Bushings - Spring Only - 1 Inch eye only
Part Number: 5.2102_rear
Thank you all for the help!!!
Series1Utiline
City: Newberg
Re: Polyurethane Front & Rear Leaf Spring Bushings
Post by Series1Utiline »
Yes, Prothane bushing kit # 41005 does both front springs the same as Energy Suspension # 5.2102.
RKT
City: Morgan Hill
Post by RKT »
Thank you for the info. No company seems to list the earlier 60's D100 as using these kits. It just seemed to me that the 1961 thru 1971 D100 2wd's would all use the same kit.
Thanks again!
Series1Utiline
City: Newberg
You're right. I just went by the spring eye (inside) diameter and spring width.
EGroscup
City: Escondido
Post by EGroscup »
Awesome info, I have 2 that need to be rebushed. Is there a part number for the shackle in the frame bushing?
