Scarebird Bracket Issue reminder
- my5thmopar
- City: Columbia
I posted this since I've seen a few recent threads about this conversion. I was trying to resolve a strange rattle from a dead stop. I checked all the suspension and steering components for tightness. Nothing found. While researching the issue, I ran across several threads from others about the brackets and/or pads needing to be modified for clearance. Well what do you know...I took mine apart today and neither L/R pad would clear the brackets. The sound was being caused by the pad binding with the bracket and rotor. I also had issue of the truck pulling hard or locking up the RH brake intermittently. Anyway, hope this helps someone else. Craig
1964 D100 Utiline
2019 Ram Classic
viewtopic.php?f=34&t=40251
2019 Ram Classic
- City: Newberg
Re: Scarebird Bracket Issue reminder
Can you post a picture of what you found regarding the location the pads wouldn't clear the bracket and rotor?
S1U
S1U
- my5thmopar
- City: Columbia
There are several threads on here. I didn't take a picture but, search and look at this picture from @slick. Its an older thread but, I think you will get the idea.Series1Utiline wrote: ↑Sat May 30, 2020 6:09 amCan you post a picture of what you found regarding the location the pads wouldn't clear the bracket and rotor?
S1U
viewtopic.php?f=20&t=35033&p=253792&hil ... ce#p253792
1964 D100 Utiline
2019 Ram Classic
2019 Ram Classic
- City: Newberg
Yes, I had seen that earlier but thanks for the reminder. I did some grind some on my pads at installation so hopefully this isn't an issue for me. However, I not only do not see a "gain" in braking since the Scarebird install, I have noticed a loss in braking efficiency. I'll pull my wheels off and have a look. It may be that I didn't remove enough material.
- S1U
- S1U
- my5thmopar
- City: Columbia
I have to agree. My manual drum brakes would throw you through the windshield. Now I have power and Scarebird and less aggressive braking. Don't get me wrong, the truck stops smooth and I like the less leg effort but, not like drums. I haven't had a chance to test since the repair. I'm dealing with a leaking axle right now. I'll report back. CraigSeries1Utiline wrote: ↑Sat May 30, 2020 12:36 pmYes, I had seen that earlier but thanks for the reminder. I did some grind some on my pads at installation so hopefully this isn't an issue for me. However, I not only do not see a "gain" in braking since the Scarebird install, I have noticed a loss in braking efficiency. I'll pull my wheels off and have a look. It may be that I didn't remove enough material.
- S1U
1964 D100 Utiline
2019 Ram Classic
2019 Ram Classic
The kind of braking for which discs matter is when the brakes are already hot, such as when carrying a heavy load going downhill or towing a trailer without brakes. Drums grab just fine, but can fade when they get hot.Series1Utiline wrote: ↑Sat May 30, 2020 12:36 pmI did some grind some on my pads at installation so hopefully this isn't an issue for me. However, I not only do not see a "gain" in braking since the Scarebird install, I have noticed a loss in braking efficiency.
- hmaynord
- City: fairhope
which you minimize on the highway by using a lower gearWildergarten wrote: ↑Sun May 31, 2020 7:16 am...such as when carrying a heavy load going downhill...
harris
driving it since 12/03/71
I almost died believing that.hmaynord wrote: ↑Mon Jun 01, 2020 8:17 amwhich you minimize on the highway by using a lower gearWildergarten wrote: ↑Sun May 31, 2020 7:16 am...such as when carrying a heavy load going downhill...
No engine braking on a diesel w/o an exhaust brake installed.hmaynord wrote: ↑Mon Jun 01, 2020 8:17 amwhich you minimize on the highway by using a lower gearWildergarten wrote: ↑Sun May 31, 2020 7:16 am...such as when carrying a heavy load going downhill...
