Power brakes on 64 with 440 issues?
- my5thmopar
- City: Columbia
I read a few older threads about this and wondered if anyone found a solution? It sure looks like I'm going to have trouble finding a booster to clear the valve cover. I sold my 70 BB truck so, I don't have anything to measure. Has anyone put power brakes on an early truck with a big block? Is the position of the master on the firewall, on the early vs late trucks different? I can get the "pancake" style for the late 70s truck front disk and rear drum that might cleat the cover. I just don't know. I have about 3.75 inches between the valve cover and the firewall. It also looks like 3 inches from the edge of the valve cover to the single master. Thanks Craig
1964 D100 Utiline
2019 Ram Classic
viewtopic.php?f=34&t=40251
2019 Ram Classic
Re: Power brakes on 64 with 440 issues?
Don't think so. Terry would know for sure.my5thmopar wrote: ↑Sat Oct 12, 2019 6:43 pmIs the position of the master on the firewall, on the early vs late trucks different?
Mopar made a lot of smaller diameter boosters out on a long bracket for the low-hood A-body cars that might work.
Russ Ashley (RussA I think) used a smaller firewall booster that cleared his big block. That was more than 10 yrs ago so good luck finding the posts. U can also use a frame mounted vac booster under the cab. That's on my 66 D100 with the 6BT.
- my5thmopar
- City: Columbia
I found his posts and I had already looked at the universal type boosters. That may work. I thought I read where someone used a 72 master but maybe that was manual brakes.
1964 D100 Utiline
2019 Ram Classic
2019 Ram Classic
- jwing68
- City: Lethbridge,Alberta
I see you have power steering why not put in a hydra booster it is relatively easy with no clearance issues and a much cleaner look. I put one out of a chebby one ton in my 67 W100 SWB if you need any info on the subject let me know. jwing68
66 Fargo W100 Sweptline SWB Poly 318
67 Fargo W100 Sweptline SWB Poly 318
68 Fargo W300 dually LA 318
66 Dodge W200 Poly
65 Dodge W300 dually Poly 318
68 Pontiac Firebird 350
2005 HD FXST Custom
66 Dodge W200 Poly
2005 HD FXST Custom
- my5thmopar
- City: Columbia
I haven’t explored alternatives but do you have a thread on here? Craig
1964 D100 Utiline
2019 Ram Classic
2019 Ram Classic
Check my build thread for pics of my booster setup from Pirate Jacks https://piratejack.net/. You might also check out the hemi-offset-style adapter from Dr. Diff http://www.doctordiff.com which will move the assembly over an inch or so.
Thank you Terry!
Thank you Terry!
Looks like they have a great selection. ThanksConrad wrote: ↑Mon Oct 14, 2019 10:01 pmYou might also check out the hemi-offset-style adapter from Dr. Diff http://www.doctordiff.com which will move the assembly over an inch or so.
I have been running an early 70's A body Dart, Valiant power booster for the last 43 years. Originally I used single master cylinder and in 1983 I upgraded to dual master cylinder braking. I custom fabricated the arm to attache to pedal from heavy flat bar. And for a year or so truck had a 440 in it. Clearance was not an issue.
What I bought for my truck. They were cheap on eBay.dodgeboykim wrote: ↑Thu Oct 17, 2019 11:50 amI have been running an early 70's A body Dart, Valiant power booster for the last 43 years.
- jwing68
Dana Hayes Hydro Booster out of a chebby one ton with over 2000 psi of boost, a good alternative for lumpy cams and low vacuum.
66 Dodge W200 Poly
2005 HD FXST Custom
66 Dodge W200 Poly
2005 HD FXST Custom
- jwing68
Another view
66 Dodge W200 Poly
2005 HD FXST Custom
66 Dodge W200 Poly
2005 HD FXST Custom
Gets busy with those hoses.
I can't see that a hydro boost requires much in the way of flow; it just needs static pressure. So with a setup like this (and given that it has an accumulator), can one use the PS pump to run the power steering as well? If so, is there a "distribution block" for that purpose?
- jwing68
It is rather busy with the plumbing, you are correct about the flow and static pressure & it is run by the P/S being first in line (series) for obvious reasons so no distribution block is needed except for the two return lines. The big Merc's & Lincolns from the seventies ran the hydro booster as well having an inline filter & a small cooler. I'm surprised more Swepties don't upgrade in this way as it is a very common upgrade in the Jeep world.
66 Dodge W200 Poly
2005 HD FXST Custom
66 Dodge W200 Poly
2005 HD FXST Custom
jwing68 wrote: ↑Wed Oct 23, 2019 11:25 amIt is rather busy with the plumbing, you are correct about the flow and static pressure & it is run by the P/S being first in line (series) for obvious reasons so no distribution block is needed except for the two return lines. The big Merc's & Lincolns from the seventies ran the hydro booster as well having an inline filter & a small cooler. I'm surprised more Swepties don't upgrade in this way as it is a very common upgrade in the Jeep world.
- my5thmopar
- City: Columbia
I thought about the hydro booster but went with vacuum. I saw a truck at the last Mopar show with electric steering and it was slick. I didn’t want to be stuck with changing both. I bought a 9 inch set up for a early Charger. I couldn’t find one for a Dart. It fits and clears the valve cover. I’ll post pix when I’m done. Craig
1964 D100 Utiline
2019 Ram Classic
2019 Ram Classic
