A745 to 727 what about brake pedal?
my5thmopar
City: Columbia
Post by my5thmopar »
1964 D100. I've removed the clutch pedal assembly by adding a spacer in place of the pedal. Has anyone moved the brake pedal pad on the arm? I would like to get another 1-1.5 inch away from the accelerator. It looks like I can grind off the rivets and either weld it back or put some grade 8 bolts in. I could probably just add a small extension to the LH side for additional support. I thought about a spacer on the RH side but, that will put the brake rod at a weird angle. Any suggestion? Craig
Re: A745 to 727 what about brake pedal?
When you removed clutch pedal you should have modified brake pedal then. Move foot pad to left or install a car foot pad onto arm. :salut
my5thmopar wrote:
Sun Sep 15, 2019 8:01 pm
I wonder if you could heat up the arm and bend it a bit
to achieve your offset without increasing the pedal height
too much? :thinking :2cents
my5thmopar
City: Columbia
Hobcobble wrote:
Mon Sep 16, 2019 10:31 am
There ya go. U iz so smrt! 2 stage. Bend to LH and angle back down. Thanks John. Craig
my5thmopar wrote:
Mon Sep 16, 2019 8:53 pm
Oh.... If you only knew me. :lol: :lol:
