Brake adjuster trouble.
Can anyone give me some advice as to what I’m doing wrong? Or what the problem may be. I installed new brakes on the rear of my 70 D100. The problem is with the adjuster on one side, not fitting correctly. The adjuster lever rests against the centerline of the adjusting wheel instead of below the centerline. I have tried different kits and shoes all with the same results. The other side seems to be fine. Would appreciate any advice.
