Another gear box question
oklamopar
City: Midwest City OK
Post by oklamopar »
Been a long time since I posted to the forums. I have been sucked into a different hobby, something the wife can do too.
On to the question. My gear box is worn out, but found a Saginaw 535 in a parts truck Ive had for awhile.I got the kit from Midwest Steering. After cleaning up the parts i found some pitting on the main gears. Didn't think they were to bad. Question is this. On the pitman shaft screw, how to tell when its tight enough? The one on the side cover.Thanks for bearing with me.
Here is the new hobby
Later,
Skip
So here's to you...
oklamopar
Re: Another gear box question
Post by oklamopar »
65 views and no help. Well i got it installed and still seems to have a lot of play. I have turned the screw in and out with not much change. Think that may have been an exercise in futility.
Later,
Skip
So here's to you...
stumblinhorse
City: Elbert County
Post by stumblinhorse »
No experience with this exact box in the D. But on my Cummins truck, Saginaw box, it can be tightened till the wheel won’t return to center while driving, then back off a little.
1969 D100 LWB 318 np435
You could buy a readily available FSM reprint and read the exact step by step process to do it.
First thing I bought for my first W200 - in 1978! There was no internet then to waste other guys' time asking questions if u were to cheap to buy the manual.
hmaynord
City: fairhope
Post by hmaynord »
also this in the technical write-ups section:
viewtopic.php?f=33&t=30487
harris
driving it since 12/03/71
oklamopar
Post by oklamopar »
PwrWgnDrvr wrote:
Thu Aug 16, 2018 8:18 pm
Thanks I will look for it
Later,
Skip
So here's to you...
search for "bishko". The reprints are better quality than the originals, yet exactly identical.
center the steering box, turn screw till it bottoms out, then just bare barely back it off, tighten lock nut. but box must be centered or you will deztroy the box
oklamopar
Post by oklamopar »
Kaegi wrote:
Wed Aug 29, 2018 9:21 am
Thanks. Did that, but still to much play. On the search for a different gear box.
Later,
Skip
So here's to you...
oklamopar wrote:
Wed Aug 29, 2018 6:35 pm
Bud Thorp rebuilds steering boxes. :idea :2cents
oklamopar
Post by oklamopar »
Hobcobble wrote:
Wed Aug 29, 2018 8:03 pm
the gears had alot of pitting on them, going to a honey hole and look for a few.
Later,
Skip
So here's to you...
