Gear box grease
Gear box grease
Ready to fill the steering gear box. 1965 manual D100. I've read to use lithium, white lithium, white lithium marine, marine grease that's blue. Does all of it work about the same? What's the best? Thanks.
Re: Gear box grease
Feels like I read that a mix of grease and gear oil? Grease alone can channel away from surfaces?
I'm curious to hear from some others here.
Re: Gear box grease
waht does manual say? gear oil only i believe. blue marine grease is terrible stuff. if any water gets in the grease moves out of the bearing and fills with the water because the 2 cannot mix at all. done use it on wheels on truck or boat trailers either. worst idea ever. I replaced many many boat trailer spindles that used it.
Re: Gear box grease
70 W200. Manual calls for SAE 90wt gear oil. That's all I've ever used in mine.
1970 W200
318, NP 445
Factory LU-2 winch
A/C, HD Gauges
318, NP 445
Factory LU-2 winch
A/C, HD Gauges
- City: Elbert County
Re: Gear box grease
I used a mix but the liquid just leaks out :).
1969 D100 LWB 318 np435
Re: Gear box grease
I read corn head grease works good for steering box without leaking out.
Re: Gear box grease
I had mine rebuilt at Benchworks and here is what they told me to do:
Every 5 years shoot hi-temp lithium/moly grease into the grease fitting until grease oozes out. I'm not sure if yours has a grease fitting or not but my 68 D100 does. If you want to discuss this with a pro who knows his craft, call Pat at (480) 946-3992. Very nice guy who will undoubtedly talk you through what is best.
68 D-100 Custom
318 Auto Utiline
318 Auto Utiline
