E-Brake Cable Install
W-200 I'm installing emergency brake cable from equalizer to right rear brake and need to know how and what position the 2 cable clamps attach to Spicer 60 differential carrier cover. It will be great having a e-brake. Thanks
Re: E-Brake Cable Install
For the brake cable, don't those clamps attach to the frame cross memberirontwist wrote:W-200 I'm installing emergency brake cable from equalizer to right rear brake and need to know how and what position the 2 cable clamps attach to Spicer 60 differential carrier cover. It will be great having a e-brake. Thanks
above the axle?
Hobcobble wrote:For the brake cable, don't those clamps attach to the frame cross memberirontwist wrote:W-200 I'm installing emergency brake cable from equalizer to right rear brake and need to know how and what position the 2 cable clamps attach to Spicer 60 differential carrier cover. It will be great having a e-brake. Thanks
above the axle?
Think your right John. 2 Bolt to frame clamp that secure from left side to right side.
My W-200 never had the right rear cable so I had no idea where the to cable clamps attached, I will look for those attachment points that was pointed out in the last reply. The used replacement cable that I bought came from a Power Wagon with the clamps so I should see on the truck where they go? Thanks
Cross member ahead of one shocks bolt to if I remember correctly. Should be 2 holes for clamps.irontwist wrote:My W-200 never had the right rear cable so I had no idea where the to cable clamps attached, I will look for those attachment points that was pointed out in the last reply. The used replacement cable that I bought came from a Power Wagon with the clamps so I should see on the truck where they go? Thanks
Figured it out when I found the two holes you spoke of. Thanks for your response.
