E-Brake Cable Install
Posted: Fri Jan 19, 2018 7:07 pm
by irontwist
W-200 I'm installing emergency brake cable from equalizer to right rear brake and need to know how and what position the 2 cable clamps attach to Spicer 60 differential carrier cover. It will be great having a e-brake. Thanks
Re: E-Brake Cable Install
Posted: Fri Jan 19, 2018 8:54 pm
by Hobcobble
irontwist wrote:W-200 I'm installing emergency brake cable from equalizer to right rear brake and need to know how and what position the 2 cable clamps attach to Spicer 60 differential carrier cover. It will be great having a e-brake. Thanks
For the brake cable, don't those clamps attach to the frame cross member
above the axle?
Posted: Fri Jan 19, 2018 11:23 pm
by dodgeboykim
Hobcobble wrote:irontwist wrote:W-200 I'm installing emergency brake cable from equalizer to right rear brake and need to know how and what position the 2 cable clamps attach to Spicer 60 differential carrier cover. It will be great having a e-brake. Thanks
above the axle?
Think your right John. 2 Bolt to frame clamp that secure from left side to right side.
Posted: Sat Jan 20, 2018 9:08 am
by irontwist
My W-200 never had the right rear cable so I had no idea where the to cable clamps attached, I will look for those attachment points that was pointed out in the last reply. The used replacement cable that I bought came from a Power Wagon with the clamps so I should see on the truck where they go? Thanks
Posted: Sat Jan 20, 2018 12:37 pm
by dodgeboykim
irontwist wrote:My W-200 never had the right rear cable so I had no idea where the to cable clamps attached, I will look for those attachment points that was pointed out in the last reply. The used replacement cable that I bought came from a Power Wagon with the clamps so I should see on the truck where they go? Thanks
Cross member ahead of one shocks bolt to if I remember correctly. Should be 2 holes for clamps.
Posted: Sat Jan 20, 2018 2:32 pm
by irontwist
Figured it out when I found the two holes you spoke of. Thanks for your response.
