brake hose issue
Posted: Thu Dec 28, 2017 12:41 pm
fully restoring my 1970 d100 and have the rolling chassis just about completely reassembled.
I am changing out al the rubber brake hoses as a matter of course. I have the frame now back on the wheels, and the front is riding a bit high of course because there is no engine weight on it; went to connect the new front brake hoses to the hole in the frame to complete the brake install and found they wouldnt reach; even with the weight of the engine they would be borderline for length to the hole in the frame where they meet the steel line. I compared the new hoses to the old ones (which I kept) and the old hoses are about 2" longer than the new ones. I phoned NAPA and the part number on the new hoses is listed as correct for 1970 front brakes on d100, d200, and d300 trucks. Also the Raybestos number is the same and recommends these same new front brake hoses.
Does anyone have any ideas why these recommended front brakes hoses are 2" shorter than my originals and will not work? The wheel cylinders are new and facing the correct direction, even though if you reversed them the new hoses still wouldnt reach.
Obviously I cant have the hoses that short as they might tear off if the suspension went to full extension like if you got a bit of air with the front end.
i do not have the front shocks mounted yet, but that shouldnt matter as the old hose is 2" longer than the new.
