Master Cylinder Cap
Posted: Thu Nov 23, 2017 11:34 am
by 61stepside
Is there suppose to be a washer under the bolt that holds down the master cylinder cap on my 61? When the brakes are applied, air bubbles come from around where the hold down bolt goes through the cap.
Re: Master Cylinder Cap
Posted: Thu Nov 23, 2017 5:10 pm
by Jim100
I think there is a washer on my clutch master which may be similar to your brake. Single pot?
jim
Posted: Thu Nov 23, 2017 9:24 pm
by 61stepside
Yes, single pot.
Posted: Fri Nov 24, 2017 12:52 pm
by Jim100
It looks copper colored on mine.
Posted: Fri Nov 24, 2017 4:32 pm
by 61stepside
Thanks Jim. When I went to check the fluids, the clutch cylinder didn't have a gasket but the brake cylinder had two. I believe the trucks previous owner must have screwed this up along with losing the washers.
