rims
Re: rims
reallylongnickname wrote:
Sun Feb 18, 2018 4:11 am
Everything is closed on weekend, but I will inquire about why I was told, gap specs.
On a different note, when I Googled, "split rims, lock rings" plenty of info and forum threads came up on discussions about lock rings flying off suddenly.
If anyone cares to read; https://talk.newagtalk.com/forums/threa ... etCookie=1
Just upgrade to 16 inch one piece tubeless rims. Lots of sources for ones that look factory. Splits are fine , But will look like crap :pale as rust starts to weep from the joints. I have switched out splits on my 66 W100 to tubeless rims :Thumbsup . And have previously done a 71 Fargo W200 and a 76 W200.
GM Rims will also work :thinking with just a little removed from center hole for hub clearance. My 66 in Avatar pic has the GM truck rims on it. Dodge caps and beauty rims fit right on.
powerwagon54
City: Washougal
Re: rims
Post by powerwagon54 »
dodgeboykim wrote:
Sun Feb 18, 2018 10:40 pm
Does not work when he has a 300 series.
Re: rims
powerwagon54 wrote:
Mon Feb 19, 2018 9:58 am
True. This post has jumped around a bit.
http://www.wheelsnowinc.com/
reallylongnickname
City: Ottawa, Ontario
Re: rims
Post by reallylongnickname »
Ok thx for input and the wheel resources
reallylongnickname
Re: rims
Seperate Q.
Michelin 9.00 R 16 XZL tires. The "R" means radials. Clearly the pic shows a split ring. Is this a tubless tire installed on a rim made for tube tire?
Re: rims
Sun Apr 15, 2018 10:05 pm
Seperate Q.
Radial tires have be mounted on split rims. Rim protector flap and Tube required. Now as to whether it may be safe or not.
That's up for discussion. :thinking :thinking :thinking
powerwagon54
City: Washougal
Re: rims
I have run radial tires on my lock ring rims for many many years. Never had a problem.
Re: rims
They make tubes specifically for radials. "radial" will be printed on the tube.
reallylongnickname
Re: rims
Gap in lock ring. As you can see one gap is much larger. So this makes no differents in safety of ring potential to come flying off?
Re: rims
The end gap is irrelevant. The gap between the ring and the rim is what matters. Is it tight? It looks to be.
reallylongnickname
Re: rims
Ok thx. Ya its tight
