W200 Leaf spring bushings ('65)
Suspension, Brakes, Tires, Wheels etc..
Postby wyota884 » Fri Nov 10, 2017 2:50 pm
I'm in the process of installing all new suspension bushings, and I wanted to make a list of all dimensions for reference.
Front leaf springs use x2 rubber bushings with a inner sleeve.
Inner sleeve ID- 1/2"
Inner sleeve width- 2-7/8"
Outer sleeve OD- 1"
Outer sleeve width- 2-1/2"
Front leaf spring upper shackle mount is a brass bushing.
ID- 3/4"
OD- 7/8"
The rear mounting bolt for the front leaf spring is 4" long.
Rear leaf springs use the same rubber bushings for the spring and the shackle
Inner sleeve ID- 3/4"
Outer sleeve OD- 1-1/2"
Same as the front, the rear bolts are 4" long
1965 W200
2006 2500 Cummins
1996 FZJ80 Land Cruiser
wyota884
City: CASPER
State: WY
Re: W200 Leaf spring bushings ('65)
Postby hmaynord » Fri Nov 10, 2017 7:30 pm
man, this will be really helpful to someone doing this job. :clap
harris
1966 (late 65 titled as 66) D100 SB 225-1, 3-on-tree
hmaynord
City: fairhope
Return to *SUSPENSION/BRAKE HELP*
Who is online
Users browsing this forum: No registered users and 1 guest
cron
