Sweptline frame strength?
HemiJoel
City: buffalo
State: MN
Re: Sweptline frame strength?
Post by HemiJoel »
HemiJoel wrote: I measured my D200 Crew Cab, right between the rear of the cab and the front of the bed. .250" thick steel, 2.40" wide, 6" tall.
I don't know if a standard cab is different. When It quits raining and dries out a little, I'll measure my D200 reg cab and my D300 reg cab.
I just measured my D200 and D300 regular cabs. I measured in the same place as the I did the crew cab, right between the bed and the cab. The D200 reg cab is .213" thick, 1.5" wide, 6" tall. The D300 is .231 thick, 2.75 wide and 7.25 tall. We need someone to measure a D100. I see that the frame width, and possible height varies a bit in different locations . So for consistency, we should all measure in the same place. When we have all the data, we could compile it into a chart or something.
1968 D200 4 door 318 auto power steering
1966 D300 slanty 4 speed flatbed with Schwartz dump
1968 D200 crew cab project to become a longbed cummins dually
CSS-Registry
Administrator
Administrator
City: Gainesville, Florida
Post by CSS-Registry »
My 1964 D100 HPP is 6" high x 2.125 wide. I'll dig out a caliper and see what its thickness is. It's worth noting mine is a rare truck and there was conversation that it used a different frame than a standard order truck. So I'm curious to see if that's the case.
Ben
Custom Sports Special
& High Performance Package
R E G I S T R Y
Here is a chart from 1968 models. Shows section modulus to be the same on 128"wb D100's & D200's.
1968
1968
712edf wrote:Here is a chart from 1968 models. Shows section modulus to be the same on 128"wb D100's & D200's.
That conflicts with the parts book, unless there was another reason the D100 and D200 had a different frame after 1966.
HemiJoel
City: buffalo
State: MN
Post by HemiJoel »
Is anyone here good enough with math and engineering to calculate the section modulus of the frames who's dimensions have been provided here? And figure out what it would be if the frame was boxed with the same thickness material? THanks,
Joel
Ya, when u box it, the modulus will be higher!
