Finally found the right leaf spring bushing!
OKCSweptline
City: Oklahoma City
Post by OKCSweptline »
Hey guys. Just wanted to put this here so you don have to go through the same trouble I did.
I have a 71 D200 camper special. I am currently redoing all of the springs and bushing in the rear end. When you search for spring bushings on a d200, most times you come up with the moog part #SB268. Well, that doesn't fit. It's 1.5" OD, and 3/4" ID. I only needed a 1 1/4" OD X5/8" ID bushing.
Anywho... I finally found the correct size bushing, and wanted to give you guys a link to it. Maybe this will help someone looking for these in the future.
http://www.truckspring.com/products/Rub ... RB-81.aspx
David
1971 D200 Camper Special
"If you want me to agree with you, I can, but then we'd both be wrong."
