Hellcat wheel set on a 71 D100
Posted: Sun Nov 06, 2016 8:33 am
by crashresq21
Need opinions. I've got a guy locally that has a set of Hellcat rims and tires for sale for $900. Seems legit yet to look at them. 20" x 9", 5 lug by 115mm (around 4.5 inches +/-)
The suspension is stock and has not been altered in any way. What do you guys think about it, will I run into some steering issues? Speedo accuracy?
Thoughts?
Re: Hellcat wheel set on a 71 D100
Posted: Sun Nov 06, 2016 9:39 am
by Hobcobble
Its the "around 4.5" +/-" that might be of concern.
If the wheels aren't a dead on true 5 x 4.5, you might be
opening yourself up for troubles.
Posted: Sun Nov 06, 2016 10:16 am
by crashresq21
And I thought the 9 inch part would have been the lightning rod for comments. Trying to get the seller to swing by and mount one of them up. By 4.5ish I meant the rims are 115mm and that translates to 4.52674 or something like that.
Posted: Sun Nov 06, 2016 10:42 am
by 712edf
Here's the chart:
http://www.tirerack.com/wheels/tech/tec ... ?techid=92
Its been my luck that close never seems to be close enough when dealing with such matters.
9" may limit your turning, plus if yours is manual steering it'll require a tad more umpf to get her turned at low speeds.
Posted: Thu Nov 10, 2016 6:32 am
by dasbulliwagen
LX LD and LC platform wheels have been used successfully on Jeeps with the 5x4 1/2 bolt pattern. I dont see why they wouldn't work on the Sweptlines. There are several members on naxja.org that are running them. I matched one up myself once and the hubs were even the same size, at least on on XJ Jeep. Hope this helps.
Posted: Thu Nov 10, 2016 7:43 am
by crashresq21
It does, thank you. I mean the 115mm is a miniscule difference from the 4.25. Now the offset and width come into play.
Posted: Tue Nov 29, 2016 1:44 pm
by TheMopars
I tried my Challenger SRT rims on my Sweptline since the tires on it when I bought it were shot.
Although they were real close and seemed to fit you could tell the weren't right once I drove on
them. I knew I wasn't keeping them on the truck so I didn't worry about, was just to get the truck
in and out of my driveway while working on it.
Posted: Tue Nov 29, 2016 2:55 pm
by crashresq21
Yeah the rears look not so legit lol
Posted: Thu Mar 16, 2017 2:21 pm
by Atmobil
crashresq21 wrote:Need opinions. I've got a guy locally that has a set of Hellcat rims and tires for sale for $900. Seems legit yet to look at them. 20" x 9", 5 lug by 115mm (around 4.5 inches +/-)
Thoughts?
The 5x4,5" bolt pattern is the same as 5x114,3mm. I have a Mazda 6 that has that same boltpattern and lots of modern cars have 5x114,3 (many japanese cars atleast). The Mazda wheels do sort of fir my D100 but they look stupid on there since the offsett is very wrong. Needs spacers between the wheels and brakes to get them to where they should be. I guess the same would be for the Hellcat wheels as most modern cars have quite a high offset compared to most older vehicles like the sweptline.
