My 1963 D300 is a top-heavy rig with a caveman camper on top. The steering, after a bumpy ride down a washboardy river road, became extremely loose. I could move the steering wheel about 6 inches before the tires would move. The steering box had previously been rebuilt by the associates from Vintage Power Wagon. The rebuilt box was then installed. The rig initially drove fine. Then after about 250 miles, the same sloppy steering reappeared. I sent the steering box back. I was told there was nothing wrong with it.
So, assuming that my steering box is fine, why is it so sloppy? It seems a bad front end can have a host of causes: kingpin and shocks, for example. But if I have 6 inches of slop before the wheel turns, and it's not the steering box, what's the most likely cause and how do I fix it?
Steering Box Conundrum
- Cleanfingernails
Cleanfingernails
1963 D300 Poly318 Custom Original Camper
- pismopowerwagon
- City: Caldwell
- State: ID
Re: Steering Box Conundrum
Have someone rock the steering wheel back and forth slowly while you look around at all the connections. Being that loose you should be able to spot it.
Andy
Seriously worn drag link is a common problem.
- slick
- City: Tucson/AZ
- State: AZ
Make sure the bolt is as tight as you can tighten it where the pitman arm is bolted the the box. Sometimes the splines can turn in the arm even though they are splined with a through bolt it can still happen..
1963 Crewcab Cummins
1961 Dodge D100
1964 Dodge Polara
1961 Dodge D100
1964 Dodge Polara
