I read my chitons and it did not refer to the leaf springs bushings, only the removal of the springs.
Do I need to remove the spring form the axle to change the leaf spring bushings ?
Leaf Springs questions
- 1surfer
- City: Breckenridge
1968 W100 4x4
2008 2500 Cummins 4x4 Crew Cab
High Rockies
High Rockies
Re: Leaf Springs questions
Technically No. But you have to support the weight of the truck by some other means than the spring you are working on anyway, so it may just be as easy to go ahead & remove the spring & replace the bushings off vehicle.
- riffraff
- City: Newport Beach
Be a lot easier also, if you have access to a press. And maybe freeze them beforehand. I went with polyurethane for the frame bushings, just because I had trouble getting rubber/metal bushings to go in.
Tom
1969 W100 383/435
1969 W100 383/435
I did mine on the truck. Support vehicle and let axel down. I used a torch and caught old bushings on fire. Push center out, the hard part is the metal sleeve out of the eye. It's time consuming.
