swapping front springs
Posted: Fri Aug 05, 2016 5:38 pm
I need a little info. on swapping from a 68 D200, onto a 69 W200. I want to know if I will run into a problem with the bolts on the end of the springs, are they the same size? I think the arc will lift my front end a bit, and make it ride a little softer. I would appreciate any feedback on doing this, and any other problems I haven't thought of. thanks, Ozzie.
