If you haven't replaced your leaf spring bushings
Finally got all my leaf spring bushings replaced there's as much difference as night and day.she's not all over the road anymore. It takes some time and its not super difficult , well worth it my 69 d100 and I are both happy
- marklein
- City: Red Deer
Re: If you haven't replaced your leaf spring bushings
Did you use urethane or stock bushings? I have to do mine and I'm leaning toward urethane.
I used urethane they are supposed to last longer and be more rigid. The rear steamed to help more than the front on mine. You still have old style truck steering but it's great.
- 1surfer
- City: Breckenridge
Where did you get them ? Part # ? I have a 68 W100 that needs them.
1968 W100 4x4
2008 2500 Cummins 4x4 Crew Cab
High Rockies
High Rockies
- 1surfer
Awesome, thanks.
Got the entire truck down to one tiny leak. Pretty proud of that. Think I can stop the last leak this week. Then the bushings and some shocks.
1968 W100 4x4
High Rockies
High Rockies
- City: Austin
Just curious if that may be my steering problem?
I just picked up a '66 D200 and the front end needs help.
Every time I hit a bump it'll pull. Sometimes left, sometimes right.
The problem is, I don't know which way. It makes for an adventurous drive down small country roads!
It's not safe and I really can't drive it until I get it fixed.
Any input would be appreciated.
Thanks in advance!
Thanks in advance!
It really helped with mine. Check excess play in stearing box may need to be adjusted. Shocks can give similar problems.
What was the part number for amazon if you have it?
jim
jim
- 1surfer
I spoke with these guys and they have the parts. Less than $150 for all.
1968 W100 4x4
High Rockies
High Rockies
