68 w200 wheel studs
68 w200 wheel studs
So I was replacing leaky wheel cylinders on the PW, started on passenger side. Took a while but got it figured out. Having to pull axle to do a brake job is a new one on me. New shoes and hardware as well. Went to do the drivers side and learned the hard way they are left hand thread. Yes I broke a wheel stud. No one around seems to have left hand threads. The napa down the road has a well recommend machine shop. Any tips on getting the broken wheel stud out of the drum/hub assembly?
68 W200 440 flatbed.
Re: 68 w200 wheel studs
From searching the forum I believe I need 1/2 x 20 studs that are 1 1/2" long. Can anyone confirm this is correct. Stock Dana 60, afaik.
Just use a punch and hammer and drive it out. !/2 inch dia. seems too small to me. Thinking 9/16.
Change them out to RH thread.FL2WA wrote:learned the hard way they are left hand thread.
left hand threads are still available. brake and clutch supply in Seattle area can match them up for you. or If you get a part number order online or give it to the parts store guys and they can order them. switching them all out is a waste of money IMO.
I might be a dorman 610201
